TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Anyone install Ulmers Front End Bushing Kit? How has it performed? Did it tighten up the steering?
My steering is very loose and in need of attention. Was looking to install Ulmers kit.
Thanks,
Kevin
Thanks,
Kevin
Randy J Beyer
- Jan 14, 2006
If Ulmer sells it then it flat works as intended ! This
we can assure you ! You can trust this man period !
If your not happy it will be a first ! Have not heard any complaints about anything they sell !
Any bushing kit will tighten up your steering if its that loose !
Let us know how it works if you do go that way ?
We are always intrested in results for all sled products !
RTX DUDE
- Mar 10, 2006
- townsend Wisconsin
- www.northwoodsrealty.net
I installed the bushing kit a few weeks ago. Doesn't tighten the steering, just tightens the A-arms. You will still have play in your steering linkage.
Put in the ulmer kit in nov before the season and it really tightened up the a arms but not the steering.Great kit.4234 miles so far on my 07 er.
Tork
super thrilled and impressed with the Ulmer oilite bushing kit.
maybe 60% better on steering slop, 100% on a arm slop
additional comments here
http://www.ty4stroke.com/viewtopic.php? ... ight=ulmer
Does the Ulmer kit include the bulkhead bushings
Tork
yes it does
there is a thread in his vendor section also
cat hunter
Ordered a bushing kit for the Grandsons Vector from Bruce at Pioneer 3 weeks ago and am still waiting!!!
Anyone try these???
Anyone try these???Honk
better call again, Pioneer is very quick. Must be something is messed up!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
guys....how much is Allens bush kit....Ill be needing one by next year as Im approaching 5000 miles very fast.
Dan
Dan
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
ROCKERDAN said:guys....how much is Allens bush kit....Ill be needing one by next year as Im approaching 5000 miles very fast.
Dan
$100.00
www.ulmerracing.com
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Any ideas on how to tighten the steering column. I have approx a couple of inches on way or the other of play in my steering.
Would the problem be around the Holder / Steering Bearing or the Univeral Joint?
Thanks,
Kevin
Thanks,
Kevin
