nbsledder
I have a 2012 xtx with 2000 miles,the bushings in the a-arms are wore out,is this normal with this kind of miles?
Dr. FeeLGooD
They will be loose when you install new ones. Need an oilite bushing kit
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
- 2015 SR Viper XTX 2009 Yamaha Nytro XTX
I did mine with 2500 miles on them. Bushings weren't shot but there was some play. If you're looking to tighten up you front end If your ball joints/ tie rods are loose it won't make a huge difference though. I couldn't ram mine for a while yet but replaced them with oil-lite bushings. A arms are tight now. It's a bit of a job but once its all done you'll say it wasn't to bad.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Dr. FeeLGooD said:They will be loose when you install new ones. Need an oilite bushing kit
X2
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
For the price difference between the plastic and oil lite I'm surprised anyone buys the plastic. I was quite surprised no one in saskatchewan stocked the oil lite though.
Ryan
Ryan
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Check out Pioneer performance bushing kits. They are comparable to the oilites. I've had good luck with them.
http://pioneerperformance.net/store/page3.html
nbsledder
Thanks for the replies,was at the dealer today and he told me all nytros have some play in the front end ...even brand new ones.He has the oil lite bushings that I will pick-up after sledding season is over,would go with the pioneer ones but shipping to me in Canada etc...it's just as cheap to buy the oil lite bushings at the dealer.
Dodge Ram
I have the pioneer. Like them. Easy to install.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Yea for some reason Yamaha is actually cheaper for a change. And even on par with what the us was charging. 79.95 is what I paid for em.
If you've got a lathe handy or now someone with one I posted a pic of the tool I made to install them. Made it very easy to install the bushings. Being bronze you have to be a little carefull installing them.
Ryan
Ryan
Ryan
Ryan
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
X2 on the oil-lite Yamaha bushings. They were bagged and tagged from MPI for $79.99.poor farmer/logger said:Yea for some reason Yamaha is actually cheaper for a change. And even on par with what the us was charging. 79.95 is what I paid for em.
Ryan
Ryan
I just used a large C-clamp for the lowers and a length of 3/8 ready rod with large washers and nuts for the top arms. I also recommend to put them in the freezer for an hour before install. It shrinks them up a little to facilitate install.
