FRONT END BUSHINGS
noahster
illinois
JUST WONDERING IF YOU GUYS COULD TELL ME ON THE FRONT END BUSHINGS HOW MUCH PLAY ON THE UPPER ARMS TOWARDS THE SLED SIDE THERE IS SUPPOSED TO BE AND THE 4 BOLTS THAT HOLD THE A-ARMS TO THE SLED IF THERE SUPPOSED TO BE A LITTLE LOOSE,THANKS FOR THE HELP IN ADVANCE
The bolts run in bushings so not a big deal to see a LITTLE slop where they go through the bulkhead if that's your concern?
THE BOLT HEADS TURN BY HAND IN THE FRONT OF THE BULK HEAD RIGHT BEHIND THE FRONT BUMPER IS THAT NORMAL???? OR DO THEY NEED TO BE REAL TIGHT??????
