Front mount dumping the exhaust into tunnel ?
MEAT
Pouce Coupe BC
I have ran mine dumping onto the track just behind the drivers for 3 years but I'm wondering if at higher boost(15+) there would be too much back pressure created by the track hauling the snow dirrectly at it ? I see the turbo phazers dont run well in the powder until you install a straight pipe. Anyone else experience this or am I out to lunch ?
It dumps in the stock exhaust hole on the clutch side, I have a flat tunnel which is alittle lower than the hole in the bulk head which may help block it from snow coming back from the track, I have a drop and roll as well which puts the track alittle lower in the tunnel
