Front shocks ?
sleddheadd
Il
Any on eknow if front shocks from an '07 rtx will fit an '04 warrior?
thanks!
They will fit, but the '07 Fox Float shocks are a little shorter than the ones designed for '03-'05 RX or RS sleds. It's because the mounting position on the '07 RTX is further away from the steering knuckle than on the Warrior, they will fit but resulting in a lower front end and a little shorter travel.
Yeah last year I got a set off of E-bay that were listed as RX size but were almost 1-1/4" shorter than my stock shocks.
I intalled them to see what would happen and the front end sits almost 2" closer to the ground and you lose front travel. It all has to do with the angle they are intalled and the rx is less upright than the Apex.
I sold them to my buddy with an Attack. I ended up buying a set of Ohlin clickers and think they are much better.
