Snowman35
Currently I am replacing all myfront suspension bushings (ulmer kit) and 1 bent a-arm and had come across some play where the spring meets the front nose of the sled. Is this small play normal? I do not see anything wrong with the bushing there. Any help would be greatly appreciated. Happy Holidays!
Honk
there rubber mounted so it should be fine. The movement is not up and down, but sideways like sliding on the rubber bushing.
Snowman35
yea movement is side to side.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Are you talking about the shock absorber?
ApexDriller
My front shocks twist as well, quite a bit compared to my friends 07 Apex RTX with Fox Floats...I suspect the rubber bushing is played out. I can turn them about 1/8th of a turn.
Snowman35
Blue Dave said:Are you talking about the shock absorber?[/quote
Yes shock absorber.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
I will check my GYTR front shocks when I get them back from Pioneer.
