APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Hey guys, I hate to bring this up again. What is the heavier Ski Doo spring you replace the OEM front rear suspension spring with when you put the Star Suspension in? I have a 2011 Apex XTX.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Hygear dual rate spring is the way to go!
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
You can use this BRP spring, part # 503192217. Inside diameter is a little bigger but it gets the job done.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I bought one of the 150-lb springs from Star Suspension with their full kit about a month ago. The spring that was sent is a Ski-Doo 503195913.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
When you say "150-lb spring" Is that how much you weigh or is this just a standard spring? I weigh around 200lbs.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
That means that the spring rate is 150 lbs per inch when compressed.When you say "150-lb spring" Is that how much you weigh or is this just a standard spring? I weigh around 200lbs.
