BLACK RX1
- Feb 11, 2004
- south central b.c. canada
- www.kencom.ca
starter relay most likely if you jump the leads on the relay it will start
replaced mine and two others
mike
mike
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Black rx1
When you say starter relay are you talking about one of the relays mounted in side the panel above your left foot (sitting on the sled, left foot). Or the relay mounted beside the battery on the battery bracket???
I ask because everyone is complaining about the relays above your foot giving them problems and my issue is not anything like the issues these guys are having. I can hear my fuel pump cycling.
the starter relay as far as i know is mounted beside the battery. how would you jump it??
It is still under warranty and if it continues to be an issue i will bring it to the dealer but i want to figure it out because i guarantee it won't have any problems starting once the dealed get his hands on it.
Thanks for your input
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
VT_Blu
Thanks for the input.
I did connect jumpers and tried to start it. it made absolutely no difference. the battery is strong.
Ya still under warranty. Dealer said he had not heard of anyone with starting issues and has no idea why mine would be acting up. (no surprise there) i bought the 4 year warranty so i am covered for a while. just need to find my warranty paperwork.
VT_BluYamaha54
- Dec 20, 2003
- Vermont
- 2012 Vector LTX
2004 RX-! Warrior
1984 Phazer (Antique)
Best of luck in getting it resolved.
Be sure to post the eventual fix here - it may help someone else!
BLACK RX1
- Feb 11, 2004
- www.kencom.ca
the relay on the batt bracket follow the big red wire from the batt has two 10mm nuts
4phsyco
I had a 2003 RX-1 that had the same problem. Finally found out that my starter relay was bad. Replaced it at 1500 miles and it ran till 9200 miles with no problem
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Thanks guys
I will try jumping the soleniod next time i have an issue.
Riding this weekend so i am hoping it won't start.
will post how i made out
Thanks again
PS - I cant believe i just said i hope my sled won't start
Thanks again
DYNAREX
if it clicks just once when the key is turned its an open in the field of the starter ,the dreaded "bad spot" on the starter-the starter will need to be rebuilt or replaced
if it clicks rapidly when the key is turned its a low voltage problem{loose connection,poor ground,bad battery etc}
- 6K
