Fuel adjustment?
It can be adjusted and it is the same steps as the Apex and Phazer. The light green wire that you need to ground is in a single white bullet connector taped to the out side of the wiring harness down by the ECU.
I've done it last night! Pretty easy!
Set all my cylinders to -10
Errol
Just installed a mbrp muffler gotta ride it now to see if it needs an adjustment. Anyone have to make a change after a muffler swap?
here
alot of it is trial and error, your best bet is to talk to other phazer owners as I do not have a clue myself.
