Sapling
I have always adjusted a carb as follows:
Main jet first
Needle position second
Pilot jet third
fuel or air screws fourth
Accelerator pump timing
Then back to number three and four if needed based on acc pump adjustment.
This has been true for two strokes and all of the four stroke dirt bikes I have owned.
As for the fuel controllers on an EFI, mine has the following adjustments
1- green - low end cruise circuit
2- Yellow - Accelerator pump
3- Red - Main jet
4- Green / blue - Boost fuel + or - when on boost
5- Yellow / blue - Lower switch point of yellow accelerator pump.
6- Red / blue - Lower switch point of main jet - means lowering rpm at which red comes on.
Do you guys have an order that you adjust these circuits? Like a carb I am sure they all effect each other.
I am not fishing or looking for specific set up numbers just in what sequence of circuits that you guys think is the best.
Thanks sap
Main jet first
Pilot jet third
3- Red - Main jet
Thanks sap
