fuel filters?
abj87
Whitefield, NH
I picked up two clear fuel filters for the RX1 i was planning installing them after the pumps to prevent any increase in vacuum on the suction side of the fuel pumps.
So the will be after the pump and before the carbs. I was also planning on leaving the factory in tank filter.
Anyone see any problems with this.
Why are you adding more filters?
Because i want to replace the filters but not drop 45bucks on the yamy filters. Plus i saw some debris in the float bowls last time i cleaned the carbs.
