HighSpeedLowDrag
2010 Nytro stalled showing code 43 fuel injection voltage. Sled has been thawed out, battery charged, fuel pump relay changed, fuses on starter relay checked, and the fuel pump still does not run. Are there any likely wire rub areas or other things to check?
