tonykof
Looking at a sled trade & the owner told me the fuel light for some reason is always on...Anyone run in to this before? I'm guessing it has to do with the low fuel light? Or are we talking about some other issue?
t
t
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
The wire is probably disconnected at the bottom right of the fuel tank. Did the owner remove the fuel tank for some reason, ie. change spark plugs ?
NFLD-Nytro
Grimm said:The wire is probably disconnected at the bottom right of the fuel tank. Did the owner remove the fuel tank for some reason, ie. change spark plugs ?
If the wire is disconnected it will flash a code though, and not just turn the light on.
I suspect it may have something to do with the float being stuck.
tonykof
okay, so it's prolly nothing serious right? I was just hoping no one would say "Oh thats a code for constant missfire" etc...
Thanks!
t
Thanks!
t
LSXM3
Mine has been like that all this year, some times when getting into the rough stuff it will actually work...lol nothing to worry about and i haven't cared enough to look into at this time.
gregdec1
Almost sounds like the fuel pump. Its like a car that has an arm that drops with the fuel level. It may either be stuck or broken. Simple think to do is pull your fuel pump and take a look.
