Fuel Pressure Regulator questions???
deepbreather
NFLD's largest city in Alberta
What does the ratio refer to on the FPR? Also, is it correct to sense charge tube pressure instead of the manifold pressure and vacuum?? P/L has a 2:1 ratio and I am thinking of changing it out to a better unit.
Any recomendations on FPR's. I see Hurricane has one but very little description on it. Someone care to shed some light?? Thanks P.S forgot to mention I have bigger injectors, if that make a difference.
The ratio is how much it rises per # of boost.
A 1:1 ratio will raise the fuel pressure 1 psi for every psi of boost is senses. Meaning if your fuel pressure starts at 50, it will rise 1:1 and then give you 70 psi fuel pressure for 20 lbs of boost.
How much boost are you running? The stock FPR might be sufficient.
The 2:1 fuel pressure regulator is a rising rate regulator. If this is what came with the Powder Lites kit I recommend you to get similar 2:1 regulator if you decide to replace the one you have.
If you run a 1:1 regulator you most likely will starve for fuel on the higher boost levels you run.
A 2:1 regulator will raise fuel pressure 2 lbs for each lbs of increase in boost pressure. If you have 5 lbs of fuel pressure at 0 lbs boost you will have 25 lbs fuel pressure at 10 lbs boost pressure.
Hurricanes regulator is a VERY nice product. I was having trouble making maps even with a walbro cls393 pump. Then I added Hurricane's regulator and problem solved. Has a nice gauge on it as well. Can't go wrong on this purchase. Another solid boost component from Dave.
