xrrider
Has any one used the Fuel Pressure Regulator from Schmidt Bros on their Phazer, any noticable performance gains? Is there any adjustment to the stock one? I've read they are on the lean side.
yzman
I got the fuel pressure regulator . and it does make a difference . more responsive and less bog . plus better fuel miliage
xrrider
Thanks yzman, I would think the engine would run cooler too.
yzman
Nope , leaning out a motor creates more heat . but i dont notice anything with heat issues .
xrrider
Yes, I'm aware of that, but doesn't the Schmidt regulator allow for more fuel vs. the stock unit.
yzman
Actually no . It puts less fuel in the motor . because the motor comes rich from the factory . All the regulator will do is lean out the motor a little .
vt phazer
would a power commander do the same.more money more adjustabilty
yzman
Yes it will . if i had my time back i would have got the power commander . expensive tho . but i adjusts the fuel injection threw the gauge . but its not adjustable like the power commander , it adjusts the whole curve , But the regulator is better for my nitrous
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
With some of the problems i've heard with the stock FPR, i'd lean more towards buying the Schmidt Bros. FPR.
