ericmichael
I'm getting a code only when its 0 or below temps. Code 43...I believe thats the fuel pump correct?I say this because I can't hear the fuel pump turn on...it happens everytime its cold out but the second the sun comes up its fine...anyone else have this problem or have a cure?
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
More than likely it's the relay freezing up.
jeffT
You could always fake your sled out with some ultra-violet tubes. You know........ tanning bed lights, then your sled wont know when the sun is up or down hahaha. just kidding. hope you find the fix. it was cold today and i froze my hands!!!
ericmichael
Crewchief47 said:More than likely it's the relay freezing up.
Yes, I was thinking it may have a small crack. Its possible moisture is trapped in there and it freezes. I'll just warm the relay up when it does this. Thank you
