I have a Simon front mount that has developed a fuel tank leak. On the return line there is a fitting that is glued into (onto) the tank and it is coming loose and leaking between the tank and the fitting. Does anyone know of an epoxy or glue that will withstand gasoline that I can use to repair this? Thanks!
