Fuse block not getting power
kschitoskey
Central Oregon
09 Nytro XTX
07 Phazer
94 Polaris 440
I have a 07 Phazer MTX. I was in the process of installing a 12V outlet using the factory accessory circuit. When I tested the wire (orange with black tracer) - nothing. I located the fuse box adjacent to the battery. When I checked the power that feeds the fuses, I noticed the outside 3 have no power. They are labeled as 20A HEAD, 7.5A SIG and 3A DC TERM. The other three are working fine. My headlights are working fine and the sled runs great.
Anyone else ever had this?
I have a 07 Phazer MTX (I posted on the MTX forum as well). I was in the process of installing a 12V outlet using the factory accessory circuit. When I tested the wire (orange with black tracer) - nothing. I located the fuse box adjacent to the battery. When I checked the power that feeds the fuses, I noticed the outside 3 have no power. They are labeled as 20A HEAD, 7.5A SIG and 3A DC TERM. The other three are working fine. My headlights are working fine and the sled runs great.
Did you have the sled running? I think those fuses are only powered when the sled it running.
Voda you are correct. Thank you - everything is working fine now.
Problem solved. That side of fuse block is only powered when the sled is running. Thanks to Voda 2000 for answering on General Phazer forum
