polcat
Need help finding the fuse for the accessory outlet next to handle bars, just wondering if has blown fuses using the electric shield with this outlet.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
polcat said:Need help finding the fuse for the accessory outlet next to handle bars, just wondering if has blown fuses using the electric shield with this outlet.
There is a fuse box just above the chain case.
Super Sled
- Feb 25, 2009
- Summit X
When you add Yamaheater Rock has you add a larger fuse in there.
The fuse box is right on right side of sled, easily accessible above the brake rotor. You can't miss it!
Mike
Mike
polcat
Thanks for the location of the fuse, have there been problems with the fuse blowing because of the electric shields.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Not when you wire it direct to the battery with an in-line fuse. Save the outlet for charging the cell phone.
- 9K
