Rukus
- Dec 9, 2018
- 2017 Sidewinder XTX SE
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
2012 Nytro XTX push turbo
The oil tank on my 2013 Nytro XTX cracked. A local guy has a tank from a vector that had the same engine. They look the same from pictures but both have different part numbers. Nytro tank is 8GL-21751-00, vector tank is 8HV-21751-00. Are these tanks the same or different?
it should work fine. the first 3 digits of the part # indicate what sled it was for. if the middle 5 match, it should work. done it before with obselete exh from and ovation onto an enticer II.
