Vector88
- Jun 23, 2007
- Happy Valley Goose Bay
- 2005 rs vector 159
wondering if a secondary clutch from a 08 fx nytro will work on a 05 Rs rage or vector. It's different part numbers but they look the same .
suburban
- Apr 19, 2003
- ontario
- 2021 SRX
will work fine, may just need to swop your spring and cam.
mnman309
Isnt the Nytro splined?
Vector88
- Jun 23, 2007
I have no clue I just see a secondary on eBay but it states it's for 2008-up sleds .
09nytro
No it won't work , the splines are different and the jack shaft is bigger
Vector88
- Jun 23, 2007
Ok thanks
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Ok thanks
Contact Travis at barnofparts.com. He should have one that'll fit your sled.
EDIT - Mr. Sled told you to contact pro116 about the proper setup on your current TEAM secondary. Did you do this?
