Fx Nytro vs Rs Vector oil tank
Rukus
Ontario
Canada
2017 Sidewinder XTX SE
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
2012 Nytro XTX push turbo
The oil tank on my 2013 Nytro XTX cracked. A local guy has a tank from a vector that had the same engine. They look the same from pictures but both have different part numbers. Nytro tank is 8GL-21751-00, vector tank is 8HV-21751-00. Are these tanks the same or different?
it should work fine. the first 3 digits of the part # indicate what sled it was for. if the middle 5 match, it should work. done it before with obselete exh from and ovation onto an enticer II.
