yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hey guys I went for a ride a few days ago and when i got back i shut machine downand had A whistling sound for about 30 seconds!
About 20 minutes later I turned the machine on (not start) and the whistling started again while the fuel pump was priming??
The fitting on that gas tank vent is the black one not the smaller red!
I traced the vent and there is no obstruction or kinks!
I sent a recording to Hammer(ty member ) hope he while post it for me since I can't post pics or videos here!
I replaced the 90 degree vent coupling and my sled still whistles.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Ok so it's normal??lolI replaced the 90 degree vent coupling and my sled still whistles.
Do you also get the whistle when turning machine on cycling the fuel pump?
3UR
- Oct 23, 2016
- Pennsylvania
- 2017 Sidewinder LTX-LE
2016 Arictic Cat 7000
2012 Skidoo MXZ TNT 800
- NE Pennsylvania
Does the noise only occur when you were sitting on the seat? Or does the noise occur when you’re off the machine standing beside it?
Mine does it but only one I’m sitting on the seat. The noise you hear is the fuel tank Venting air... this is normal
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
It does it when i am standing beside the machine (both when shutting off machine and priming fuel pump
Its typically after the machine has been running so the tank has time to pressurize. So yes, i have taken it as normal! lol
3UR
- Oct 23, 2016
- Pennsylvania
- NE Pennsylvania
This is different from what mine does mine only makes that whistle noise when you’re sitting on the seat with or without the engine running
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
It’s normal. The tank is meant to hold a certain pressure per EPA rules to keep vapors in.
When it vents it whistles as the air goes past the pressure relief built into the tank vent.
No worries.
No worries.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No worries.
Hi Knapp thanks is it normal to get whistling when the fuel pump is priming also?
KnappAttack
- Feb 19, 2004
- Welch MN
Yes it can vent at any time either in or out. Also, will whistle if you want to call it that as fuel runs thru the regulator and return system.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks!!I've read about it venting outYes it can vent at any time either in out out. Also will whistle if you want to call it that as fuel runs thru the regulator and return system.
Hearing it hissing while pump was priming had me a little consern!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Trying to upload recording it won’t let me or video
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks for trying Pan!!!Trying to upload recording it won’t let me or video
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
If anyone can guide me been searching this site can’t figure outThanks for trying Pan!!!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just went for a boot and no whistling this time!!!
The hurricane270 sm tune is crazy...lol
