gasket questions ?
ProstockBenji said:
when taking apart and reassembling a RX-1 engine what is a must to replace of the gaskets?
head gasket? exhaust manifold gasket? etc??? thanks
Benji :4STroke: :yam:
Definately the head gasket I have reused the exhaust gasket with no problem but inspect yours for leaks and replace if necessary.
I also replaced the valve cover gasket and seals under the bolts, cheap insurance.
you will need oil pan gasket, gear reduction cover gasket and fly wheel cover gasket, that should do it with the others mentioned, replace the pto shaft seal while you are there. this is assuming you are taking it completely apart not just doing the head work.
