rxwhopper
i think its reason number 2 why it never worked for turk lmao
yami ryder
I went up to the 22 gear with stage 2 clutch kit and excell exhaust, It for sure doesn't have the low end pull it had when stock and it won't launch off the moguls like it use to. I did see 104 on the speedo when before the most I seen was 94. There is a gain on top big time. I am going to run it with my wife's stock rtx and see what the gain is, if not much I am going back to stock gearing..
NB-NYTRO
Can you pm me your set-up in your proline??
With the stock clutch kit and gearing change I am only pulling 8600 to 8700 RPMS.... it will hold there to 93 mph and have not had the room to hold it longer.
I had a proline kit in but was trying to trouble shoot some other stuff so I yanked it....
I may go back to stock/stock
I would have the same problem.
