rx1turbo
- Jan 6, 2007
- Burns Lake British Colombia Canada
Rx-1 rear mount mcxpess 9 tooth drivers running 162 cut down track just wondering if any suggestions for gearing. I'm running 23/41. Running 350 hp range
satan660
what chain are you running with that gearingrx1turbo said:Rx-1 rear mount mcxpess 9 tooth drivers running 162 cut down track just wondering if any suggestions for gearing. I'm running 23/41. Running 350 hp range
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Need to know what speed you can go on radar in 500 ft to better help you.
rx1turbo
- Jan 6, 2007
I'm running 15 plate hivo. I was running 151km/h with approx 300hp last year
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
rx1turbo said:I'm running 15 plate hivo. I was running 151km/h with approx 300hp last year
I would gear up to 38 on bottom.
rx1turbo
- Jan 6, 2007
Will it be that much of a gain?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
rx1turbo said:Will it be that much of a gain?
I beleive it has to help since your geared right to the max right now, and on snow the track is Always Spinning, So in order to go faster you need to spin the track Faster.
rx1turbo
- Jan 6, 2007
So even with a 162" 1 1/2 track you figure I'm still spinning at the end of 500'?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
rx1turbo said:So even with a 162" 1 1/2 track you figure I'm still spinning at the end of 500'?
Yes.
rx1turbo
- Jan 6, 2007
ok ted thanks for the help
