Just as the subject reads, my newly installed MPI / GEMS unit causes a code 15 84 to display. 15 = throttle position sensor and 84 = TORS. TORS will display anytime the throttle position sensor faults so I'm convinved 84 will clear upon clearing code 15.
When I take the GEMS out and reconnect the factory harness, no codes display. So, the GEMS is driving this.
Is this normal or is there a problem?
Thanks for your help.
Jim
