redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
This is not about my Yamaha, but my 2001 Polaris. The Polaris forum sucks compared to this one, so that's why I am asking.
The Polaris has the old metal skis and I want to install a pair of Kimpex skis. I got the right side out easily by just removing the locknut and whacking the bolt out with a few taps with a hammer and a block of wood. Not so easy on the other side. The ski pivots and turns without a problem, but that damn bolt will not come out! I have whacked it HARD with a hammer (to the point where it is starting to bend on the threaded end) and it will not budge. i cannot figure out what is holding it up either.
What are your suggestions for getting that stuck bolt out through the spindle???
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
it is seized in the bushing. It has rust build up locking the bolt in there.
redrx1rkt
- Apr 20, 2005
How do I get it out?
sherlock29
put the nut back on, about 3/4 the way... use a small piece of wood, 2by4 or whatever... and get a bigger hammer. the nut will protect threads from getin bunged up and the wood well... helps not destroying the nut... clear as mud??!! it will come out...
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
well I am not sure what yours looks like but when I would have a seized busing on my control arm on my Jeep I had to cut both sides of the bolt off so I could get the arm off and drive the bushing out of the rubber. On a small bushing in the snowmobile I would think the only way to get it out is to drill it with a small bit and get bigger, as a last resort.
radianguy
- Jan 1, 2007
Spray it down with some penetrating oil and let it sit for a bit, then it should come out.
dexter
I had this same problem with my 89 scoot... ended up cutting inside the saddle on both sides. once out the I could not see a gap between the collar and bolt. Unreal...must have never been off and they rusted together. good luck.
Zakre
if its metal skis you could warm it up then whack it.
could be a bent bolt. may have to drill the center with a small drill bit to make it weak.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
Heat, Vibration, Penetrating oil, & Force.
All of these (and usually a combination) will get most frozen bolts out.
As stated above, apply penetrating oil & let sit a day or two. (Can always re-apply the oil a few times.)
Try heating the bolt with a torch until it is almost cherry hot, then let it cool off.
Put the nut on & then give it a good whack with a heavy hammer.
This combination usually does it.
Hope this helps!
Hope this helps!
redrx1rkt
- Apr 20, 2005
Thanks for the advice!
I will give the penetrating oil a try first, then the hot wrench. If all else fails, I will ride with one Kimpex and one metal ski this winter! Good way to compare 'em! JK - may have to lure my mechanic neighbor over with beer if I can't get it this weekend.
