Every once in a while I lock myself in my shop with just the sleds, quads and my grease gun... Well I went balls on my wifes XC first and greased that all up... Then I attacked my rhino and it had grease hanging from everything.... Then to the apex...I greased all the fittings I could find on the skid ( I found 7... Is there any more I missed???) then I did the driveshaft and jackshaft bearings... (((drive shaft was quite dry and gunky so I cleaned it all up first, jackshaft wasn't as bad and had some grease left)))..... Then I did every wheel in the skid.... and lastly the two fittings on the ski spindles...
My question for you guys is....... Am I missing anything on the apex??? Since I still got grease on my hands Id like to make sure I hit em all...
I drill a arms and ski bushing with 1/8 and use needle tip and also all steering bushings including remote lines to steering front of tank. steers like a wet dream
