fldodge
when going from 121 to 144 will i have to move the small heat exchanger which replaced the crossover tube from its factory location to the rear of the new tunnel extension?
If I did this correctly, read through the following link.
Not sure exactly how you plan on getting to a 144", but you may have a similar issue as I did.
My 07 shown in the pictures only had the crossover tube. Does the heat exchanger you talk about sit more or less parallel to the snow flap? (About 20 degrees off of vertical.) If so I would recommend relocating it so it is mounted horizontal/flat on the bottom side of the tunnel extension.
PM me if you have any more questions. Hope this helps.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
fldodge
so you never had any interference issues or rubbing at full compression of your suspension?APEX 06 said:I keep my rear cooler in the same place when I did my 144" set back.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Not in almost 3000 miles with 1.75" lugs.
fldodge
did you have to trim that aluminum frame section directly behind your heat exchanger?APEX 06 said:Not in almost 3000 miles with 1.75" lugs.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Nope I left it the way it was.
granto211
Dont waste ur time with this, i changed nothing with that. 3000 miles and 7 sets of slides later no issue besides slide ware. Fixed that by runnin 65lbs of air in my front shocks which made the sled sit back on the track more. Along with taking the limiter strap in 2 notches tighter
apexrtx10
Are you guys running studs? I'm going to 136 and have the same questions about rear cooler, I'm going to use studs though. and was thinking I will have to move the cooler to the back of the tunnel so it won't get hit.
granto211
I dont see how this would be effected? Nothing changed from stock, if it woulda hit it woulda hit stock. Just bolt the extension over old tunnl.
