jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The two plastic pieces that fit together around the steering rod/post?? I could see that .found a squeek on mine up front...it was the steering post blocks..lubed and loosened one slightly too tight block...quiet and smooth as can be now
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yep...one was over tightened and squeezing the snot out of the post...draggy and squeaking here and there......nyloc nuts with plenty of thread showing anyways.....so greased and loosened and butter smooth and quiet now
thunderbolt
any chance we could see a picture?yep...one was over tightened and squeezing the snot out of the postdraggy and squeaking here and there......nyloc nuts with plenty of thread showing anyways.....so greased and loosened and butter smooth and quiet now
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
I hear a squeak too. Seems more noticeable when rear of sled is springing up I think. Going through some washboards gets annoying.I'm hearing the same squeak, drives me nuts, my viper had the same and of course no grease fittings in the front end.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Are there 4 fittings on the 129s as well !
Pstn head
I don't beilieve so, I could only find threeAre there 4 fittings on the 129s as well !
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Thanks I thought I was going blind...lolI don't beilieve so, I could only find three
Pstn head
Ha ha ha Same hereThanks I thought I was going blind...lol
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Sounds like the noise is coming from your rear end. Cooking with Olive Oil can remedy that...
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Damn squeak got really bad today. Trails were pretty chopped up by the end of the day. I greased the 4 zerks myself and they were just done again by dealer. So, I am positive it's in the front. Still waiting for pics SJ of the area you mentioned. Otherwise, I am gonna silicone spray the entire front end (besides that will help prevent ice build up in intake. Lol)
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Lower ball joints like to squeak on this chassis. I pull boot back enough to slide grease needle in there than pack her full.
Sent from my SM-G920W8 using Tapatalk
SnoGlider
- Mar 23, 2020
- 46.8419, -68.1554
- www.facebook.com
- 2108 Yamaha Sidewinder
Thanks for this post. Was only finding 3 on my '18. Found this post and looked harder. Found the last one. I have a 137 LTX 50 year LE. The 2 at the back are easy to see looking back. The one up front toward the middle of the track is located high and can be seen when looking forward. The last one is close to this one but lower and a little toward the back but still in the center of the track and can be seen by looking back and down.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
The squeak comes from the sway bar bushings where they ext the chassis. Viper had it and so does this sled! I’ve used a good Teflon spray on them since 2016 and it lasts for a good while!
RAMSOMAIR
4 grease fittings in the skid, trust me..
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No more squeaks
https://www.mainwaysolutions.ca/ms-products.php?action=shop
I believe he is a vendor here
