Grizzly fan stopped..............
Grizzly Dan
Sheboygan,Wi./ L'Anse, Mi
LOCATION
I have a 03 grizzly 660 that the fan quit working on a ride. I wired it direct to a hot wire and the fan worked for the rest of the ride. We went 440 miles in 2 1/2 days. Only problem with that was it drains the battery and I had to pull start it when we stopped. I put a switch on it for now but does anyone have an idea where the problem is? Circuit breaker, thermo switch maybe and where are they?I'm going back up tomorrow night to check it out. Maybe someone out there can help figure it out before I leave. Thanks!
Not sure if there is a fuse on the fan but I would assume there is. I would start there. Look in your owners manual for it. If not there is a thermo switch on the bottom left side of the radiator that could be bad. Go to grizzhoppers website and look up the fan overide switch. That should give you a good idea oof what it looks like. Never mind here's a link to it.
http://grizzhopper.com/Fan-OR.html
