burg226
- Jan 24, 2011
- Newcastle, ON CANADA
- 2017 Arctic Cat 9000RR
Just doing some periodic maintenance over the past couple weeks in anticipation for the late start to the season and I noticed that the primary clutch faces have developed (or have had all along) grooves in them. They appear to be at bottom of the clutches and on both sides.
How will this affect the engagement, etc? Is this normal (don't think so) and how can this be repaired?
Is it as simple as taking a file or some sandpaper to it? Has anyone had success with repairing them this way?
Sled is a 2008 Apex LTX with 20,000km.
Your thoughts, experience and input would be most appreciated!
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Run it. I wouldnt worry about it that low in the clutch. I have seen this many times.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
wouldn't worry about it. i'd be more concern if there were fatigue cracks down there but by the pics you're good.
YAttak07
I have the same groves which developed very early on.....believe it is caused by the very hard yamaha belts. they are much harder compared to aftermarket ones.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Are these the grooves that some people have "cut-down" so the clutch can close more to gain a little more Top-end? At 2500 miles my new clutch has the same thing.
burg226
- Jan 24, 2011
No, the reason these grooves appear this low in the clutch as per Schmidt Bros Motorsports (The company that does the overdrive machining to the clutch faces), is because of late engagement. They offer a "Comfort Spring" that will lower clutch engagement and reduce the hard impact on the clutch faces. Not sure if I'm sold on doing all of this yet. Might just leave the clutches for the season and think about doing it in the off season if I start blowing belts or losing performance.Are these the grooves that some people have "cut-down" so the clutch can close more to gain a little more Top-end? At 2500 miles my new clutch has the same thing.
Would these grooves affect or destroy my belt? Anyone run for a long time with these grooves?
sgauthier
- Mar 5, 2009
- 2011 Apex XTX
not sure why it would effect your belt, it's only there at idle
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I got the same Grooves in my primary they are slowly getting worse thet is where the clutch first impacts the belt mine are alott worse then yours I would not put much worry into it. I plan to look into it in the spring for mine but from how yours loooks VS how mine looks you have a full season to get to the point mine are at at least. but if you find a solution please post.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Yes, that makes sense. I put my Attak spring in the used Apex clutch I recently acquired. I had 11K on the last clutch in my Attak and it NEVER gave me a problem. I change the spring every other season though.No, the reason these grooves appear this low in the clutch as per Schmidt Bros Motorsports (The company that does the overdrive machining to the clutch faces), is because of late engagement. They offer a "Comfort Spring" that will lower clutch engagement and reduce the hard impact on the clutch faces. Not sure if I'm sold on doing all of this yet. Might just leave the clutches for the season and think about doing it in the off season if I start blowing belts or losing performance.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Belt wear!
burg226
- Jan 24, 2011
???Belt wear!
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
The Yamaha 8DN belt wears the clutches. ie Belt wear!
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Belt wear!
exactly....hard belts do this.
Same thing was a big problem about 15 yrs ago when GATES first entered the market with their 'extreme' belt....it was so hard it was putting groves in SkiDoo clutches very quickly!!
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Yep since 2003 at least, My Warrior has 18,000 miles with the 8DN, clutches have grooves but everything works normal. My Apex has 7,000 but I don't notice the grooves so much on it yet.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
I also have the same grooves in mine and may switch to an Ultimax, or whatever else people have used and have had good luck with?
