sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
YOu guys know the difference in these Ohlins springs from the Apex GT?
00696-08/48 L165
00696-11/54 L076
00696-08/48 L145
00696-08/48 L165
00696-11/54 L076
00696-08/48 L145
sledheadgeorge
- Apr 28, 2003
TTT Come on, guys no onw knows?
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The first and third spring are stock Apex GT springs rated at 4.9kg - the middle spring is a 5.5kg spring. The 696 number designates what type/style Ohlins spring it is. The 08 and 11 numbers designate what the rate of the spring is - every number higher represents .2kg greater in spring rate (ex. a 6.1kg spring would be 696-14 and a 6.5 is a 696-16). The last numbers (L165 and L145) I believe are just production numbers of some sort and have no bearing on spring rate or performance. Here's a link in our vendor section that has info on all the stock and optional mono-shock springs offered by Yamaha. Hope this info helps.
http://www.ty4stroke.com/viewtopic.php?t=22583
sledheadgeorge
- Apr 28, 2003
Thank you
