TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
2006 RTX Mono Skid. Anyone know the bearing model # for the guide wheels? Wheels are ok but the bearings are shot. Yamaha only sells the entire wheel with bearing. Looking for replacement.
Thanks in advance,
Kevin
Thanks in advance,
Kevin
terret725
depending on which one it is it will be a 6205 rs (25 mm or 1 inch inner diameter) for the fronts or a 6204 rs (i think may be a 6004 rs) for the rears with a 20 mm inner diameter
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
terret725 said:depending on which one it is it will be a 6205 rs (25 mm or 1 inch inner diameter) for the fronts or a 6204 rs (i think may be a 6004 rs) for the rears with a 20 mm inner diameter
Thanks, much appreciated
terret725
it should actaly say it right on the bearings when u take them out. either on the seal or laser etched into the inner race.
LJ 452
Which wheels are you talking about? If its the two outside rears your going to have to buy new wheels as well. The silver plastic spoke thing covers the bearing. If it's the stock anything other that the one center rear wheel, you'll hae to buy wheels as well. I would recomend the spoke style in the Yam accesories online. They look nice have replaceable bearings and will be a direct bolt on. Heres a pick of mine. The two wheels that whould be on the inside of the skid aren't there because I was waiting for the parts but you can use the same ones there as well.
