h/h
Blue shadow
CANADA NL
At 20 psi I am running heavy hitters at 85 grams .She hits 10900 and drops back to 10400 .How much more grams should I put at the heal to keep it at 10400?Thanks :Rockon:
The most you can run in the heel is a 1/4 & 3/4 screw. If your maxed out then you need diferent weights or a helix with a steeper initial angle.
