Help- clutching for the UP
BigDog05
Pittsburgh,Pa
I'll be going to Newberry on the 18th for a week.
I'm presently running a CPR clutch kit I got from Matt last year. Only thing different is I'm running the white spring at 60 instead of the silver at 100.
y/s/y primary, heavy hitters with 3/4" allen in heel, 7/16 steel bolt in #2 and #3 holes. Total weight 74.6-74.7 each.
Between 2200-2900 ft elevation at 10 lbs boost, I'm running 10,200-10400 depending on conditions.
I'll be lowering the boost to 6lbs while in the UP.
How much weight should I take out of the clutch and should it be out of #2 and #3 or just #3.
Thanks for any help in advance.
Remove 2 grams inner & 2 grams outer. Leave heel the same. This will be very close
