shawnj
So It was a mild day just above freezing. I took the Apex for a little rip and brought home and parked it outside for a few hours. When I went to start it to put it away code 20 showed up and had the yellow light and also the engine light flashing. I shut it off and restarted it and it went away. I see it is do do with atmoshpheric psi or something along that line. Has anyone had this happen and has it rehappenened? I wondered if it were just the damp weather causing it.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Code 20 is:
Intake air pressure
Atmospheric pressure
If the error code goes away it's nothing to worry about. If it's reappering regularly you may have to change the sensor.
Intake air pressure
shawnj
Great thanks. I think it was the weather that may of caused it as it went away when I started it up the other day again. Thanks. I was just worried I may of forgotten to plug something in when i did the donuts last spring.
May have iced up the passage and tripped a code 20. Happened to a TY'er on our TY Ride last year. After the first stop the code went away and never came back
