error code 20 and 14
Fast_Eddy
Vanderhoof (area) Canada B.C
Website
www.sledwest.net
went to the cabins on the weekend and it went down to -37C.
my 06 apex rtx did not want to start. had to boost it to get it to crank over and it had error code 20 and 14. the 14 went away when it started 20 went away after shutting it off and re starting.
What do these codes mean? i have seen 20 a few times befor on a cold start. i read it might be a air box code? i do have a modded air box if that info helps.
Error Code 20 is telling you the Airbox Pressure is not correct. If you have modified you airbox, then you may see the code from time to time.
Error code 14 is telling you that something may be eclectically wrong with the Airbox Pressure Sensor. Seeing how it cleared quickly, it could have been because of the low battery condition.
But, ... read this. CLICK HERE
