pintokid
- Oct 7, 2017
- cny
- 09 fx rtx nytro 121
if i turn my hand/thumb warmers off then unhook them and the switch (completely eliminating the warmer system) , will it throw a code?
I've wired rsi elements, and nci thumb drive element, direct to battery via dial resistor and relay from taillight wire. (bypassing all ecu controll)
with the switch connected it could be bumped causing a code if warmers aren't connected (no ohms load). if i can unhook the switch also without a code it eliminates that possibility.
pintokid
- Oct 7, 2017
- cny
A; i got a code 81.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
grip warmer- open or short circuit detected.
pintokid
- Oct 7, 2017
- cny
yeah. i was hoping if i unhooked the whole system while it was turned off that it wouldn't. oh well. 8 ohm resistors i guess.
sportster64
My one grip warmer doesn't work, and I get no codes, how can that be ?
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
I lost my left grip warmer last winter. The element burnt out...was ripped where it turns down on the grip. Replaced it that night with an aftermarket element. No codes thrown..just age and wear
