Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
I've asked this question on the 2 stoke side of the site but haven't gotten any responce. Can a sno scoot's electrical system handle hand warmers?
I have an 88 with electric start but I want to warm my little guy's hands.
SharkAttak
try it
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
I would rather here if someone elses has done it before I invest the time and money in a possible losing cause. If it has never been done I will be the first I guess
SharkAttak
i've never seen a sno-scoot, with hand warmers
srxguy
I am sure it will work. You have a battery right?..Just hook then to a switch them run it to the battery
LazyBastard
I ran hand warmers on an 82 ET300. Should be fine as long as you've got some power.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
I would rather not run them directly from the battery. If they get left on they kill the battery
LJ 452
Run them from a switched relay, from the battery. Basically use something that is only on when the sled is running, ie headlight or something. Use that circuit to switch the relay which will then feed power to the hand warmers directly from the battery. Just make sure you use some type of output control ( high/low switch w/resistor) or you might get a little toasty, this apply's regardless of how you connect them to the sled.
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
I have them on my sons scootand had them on several others as the previous poster said
SharkAttak
did you do it?
