kl_dave
anyone lose a hand warmer yet, out riding last saturday, noticed one hand getting cold, right side hand warmer not working on high or low ! no codes either
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Nope not here.
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
My right one is weaker than the right.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I lost the little light on the switch the first weekend, but the warmers still work. Just something minor for the list of stuff to have looked at after the season.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
mine both work, and are still working. They are so damned warm on high I swear they will melt gloves if not turned down, which is a huge improvement over my cold-handed apex. Im honestly looking at handwear that isnt so warm!
However, the thumbwarmer seems completely useless. Curious to know if I just seem to have no arteries in my thumbs, or if others have this issue as well?
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
My wife's right hand warmer didn't right out of the box.
Replaced and no issues in 500 K.
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
My left one didn't work out of the box. It was a defective 2 pin plug. I could make it work but only while sitting still. The dealer said he had seen this on the cats in past years.
stingray719
My Cat right side is weaker than the left but works. Girlfriends Viper both grips will actually burn your hands on high.
kl_dave
gotta get some time to get into the shop and let the boys figure it out, new track going on too 2.25 power claw
Yes at 0 deg i am riding with mechanics gloves and warmers on low. Even on off they seem to be warm.
TJ-R
- Jan 28, 2013
- 14 Viper XTX
Thumb warmer not working
My thumb warmer doesn't seem to be working at all.
Wondering if anyone has had the throttle side casing open and if there is a connector there to take a power reading from, to determine if ti is the thumb piece or no power to it.
Since the wire passes through the throttle block there is no way to tell which wires power the grip vs the thumb warmer; does anyone have a wiring diagram?
DigitalFusion said:However, the thumbwarmer seems completely useless. Curious to know if I just seem to have no arteries in my thumbs, or if others have this issue as well?
Re: Thumb warmer not working
Mine is in the shop for another reason (blown up) but thumb warmer has never worked and they are supposed to be looking at it.
TJ-R said:DigitalFusion said:However, the thumbwarmer seems completely useless. Curious to know if I just seem to have no arteries in my thumbs, or if others have this issue as well?
Yamacat21
My thumb warmer is intermittent. Sometimes it'll burn you and others I have to take my glove off to see if it's even on.
warmers
Both grips heat great on high but thumb warmer isn't heating at all, will have it looked at seasons end when I have the reverse servo fix take in for replacement
Jamie Gelting
- Feb 19, 2007
- Merton, Wisconsin
- 17 Yamaha Sidewinder, 14 Yamaha Viper, 07 Yamaha Phazer FX
The thumbwarmers don't get hot on any of them that I have seen...Only Warm not Hot. My cat had the rt warmer go out and I just decided to put on the RSI's myself since the cost would be a lot less than me driving everywhere for a $45.00 warranty part. The RSI's have a lower Ohm rating so it ashould be a little hotter and them seem to not be as delicate.
