marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
Wondering if anyone can tell me what the height is for the stock riser on 06 Apex ER/RTX/GT vs. what the height is for the 07? I don't have access to either year sled at the moment, and if I recall correctly the 07 and 08 riser is taller than the 06.
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
3.5" on 06 and 5.5" on 07 and newer.
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
Thanks!
Capt.Storm
Will the 5.5 bolt right on to the 06 without mods?
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
The bolts go all the way through the riser, so if you get the correct bolts and the taller riser it will work.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
If your spending the cash go for the mountain riser. 1 1/4 inches higher again. I have it on my 08GT and love it
06 handlebars sit taller than the 07's and up.
Capt.Storm
The way there talking the 07's and up are taller?watersuper said:06 handlebars sit taller than the 07's and up.
I know on my 06 thier not tall enough..I want them higher...But I dont want to get longer cables or anything...just wondered how high i can go with out changeing anything else...the eaiset and cheapest way that will look and work good.
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
07-08 riser blocks are taller
Capt.Storm said:The way there talking the 07's and up are taller?watersuper said:06 handlebars sit taller than the 07's and up.
If you use the 06 bars with the 07+ riser, the grips will be higher than any year Apex except the Mountain version. Will not need cable extensions if you do this.
Capt.Storm
watersuper said:Capt.Storm said:The way there talking the 07's and up are taller?watersuper said:06 handlebars sit taller than the 07's and up.
The guy that had it before must of changed it allready..it measures out at 5.5(the block)..and I'm using the 06 bars...thanks.
Still could be taller..I'm 5-11 and I still have to bend alot standing.
Capt.Storm
I just measured the riser with it put back togather...now it seems to measure out at 3.5 inches.
Do you measure it with the cover off or on..man this is getting goofy...lol.
vmaxcrazy
Just get a 2" rox riser. There about $70. Unless the yamaha mountian riser is cheaper. The added bonus with the rox riser is you can move handlebar forward or back a little from stock angle. And yes you can still use yor stock cbls. You just have to reroute them under the chrome ring at base of riser.
Capt.Storm
Sounds like a plan...thanks.vmaxcrazy said:Just get a 2" rox riser. There about $70. Unless the yamaha mountian riser is cheaper. The added bonus with the rox riser is you can move handlebar forward or back a little from stock angle. And yes you can still use yor stock cbls. You just have to reroute them under the chrome ring at base of riser.
