ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Hey all....
Ive spoke about this before....I just thought Id put some pics up and show the comparison between the NYTRO bars and APEX(06) Bars.
For anyone who is waiting still for APEX updated bars...most dealers HAVE NYTRO bar Updates instock...while APEX updates are all backordered...you CAN use NYTRO updated bar kit and simply BUY a 07 APEX riser block...this will make your 06 APEX IDENTICAL to and 07 APEX.
FACTS on bar updates....
-06 NYTRO,07 APEX,07 NYTRO are all IDENTICAL BARS.
06 APEX bars were different,so yammie decided they would make ONE BAR from now on,instead of one type for NYTRO and anothe Type for APEX....this is why you can get NYTRO updated bars easily,since they are identical to 07 APEX bars.
because of this,the UPDATED APEX bars are STRICTLY BEING MADE for the 06 guys with poor heaters.This is why yammie is making them slowly,as they do not want to get stuck with leftovers,they obviously didnt make enough.
Personally when i found all this out..i felt i would much rather make my 06 APEX IDENTICAL to all 07 APEX's....but to do that you need to buy the taller riser since the nytro/07 apex bars are FLATTER(less rise)
So for those who dont want to wait,and like the LOOK of a taller alum riser block,just take the nytro update,which is exact same as the 07 apex bars...and order a 07 apex riser and 4 mount bolts...the caps can be reused.
After all,if you smack up your UPDATED 06 bars youve been waiting forever for,you probably wont be able to BUY those bars 2 yrs down the road,you will probably have to buy 07 bars and the taller riser...since yammie is only going to make enough to get them out of this mess.
In these pics..you can see the RISER BLOCK for 07 VS. 06 riser...its about 1-1/4" taller,however......when you see the new FLATTER bars ontop,you can plainly see the END RESULT HEIGHT is near EXACT same as the 06 APEX was.
SO,if you cant wait and dont mind spending approx 57 bucks for riser and bolts,see if your dealer has NYTRO update instock....the riser came in 3 days and is NOT on backorder.
the Pics truly say it all!....
