yamahagirl
- Oct 30, 2003
- Upper Michigan
- www.boneymasonry.com
Has anyone put in more than a 1in riser? I know you have to extend the cable and what not, but who has done it.
I am thinking about the muffin riser, but really want more than 1in
Phazed-Coug
I used a 2 inch ROX pivot, and all I had to do was route the throttle cable under the bar instead of over.
yamahagirl
- Oct 30, 2003
- Upper Michigan
Thanks I will look into re-routing the throttle cable.
Did 2 inches raise the bars enough for you? I had 4 in my viper, but I think 2 will work with the set up of the phazer.
Phazed-Coug
Rerouting the cable is pretty easy, just have to do it right at
the handlebar. While your at it make sure the cable running
down to the engine is routed nicely, I know someone
mentioned once that theirs wasn't routed cleanly.
I'm 5'10 I think its adequate but its the highest I think you
can go without buying a longer cable.
not a great picture.
I guess I could go higher and be okay, but I didn't want
to get into putting a longer cable on. and I think the brake
line would need to be extended as well above 2 inches
