jeremy377
looking for the measurements on the xtx 1.75 handlebars. i could use the rise from mount point to bar tips and the overall width of the bars from end to end. long story short i had an argument with a gravel pit that won and bent my bars with 115 miles on the sled
. i am going to do the oft relocate and pro taper bars for a fix but need some numbers to choose a riser block size to fit the bars i am purchasing. thanks in advance folks.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
your steering relocate should raise bars up about 2"-2 1/2" along with moving it forward. i think i read somewhere that you can add 2 2/2" riser to that with stock bars max, without longer cables etc... i will be going out to the shop a little bit later and i will get you the measurements. do you want measurement for bar rise (straight part of bars....where controls/grips are) or to the ends of bar hooks?
jeremy377
that would be perfect thanks for the help and yes i want to keep the stock cables to make it easier
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
which measurement do you want?
jeremy377
Rise from bar mount point to very top of bars at curve in hooks would be awesome
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
about 2 1/2" rise on stock bars.
pm me your email and i'll send you some pics of OFT installed. I am just hanging out in the shop at the cottage, can't go riding today.
mx1500
i have stock bars and 6" riser with no extensions
