mattchew_3
- Dec 28, 2014
- SR Viper
Can anyone tell me if the bars are 7/8 or 1"?
Sent from my SM-G920R6 using Tapatalk
7/8 I believe.
mattchew_3
- Dec 28, 2014
- SR Viper
Thank you! Are you the guy that revalves shocks?7/8 I believe.
Yes sir! Also just confirmed bar dia. .875 exactlyThank you! Are you the guy that revalves shocks?
mattchew_3
- Dec 28, 2014
- SR Viper
How much do you get to do a set and what kind of lead time do you have? I have a 14 standard model
For just a refresh its $30 a shock. If you have standard model you will need to call me since it will be custom valving for you. Those shocks are pretty close valving wise unlike the 2in rears. So $80 for center shock revalve and less for the rear since wont need all the shims changed. (920)323-1973 cell Thanks
3 day turn around not counting weekends and if snow flys I ride so lead time varies then,
mattchew_3
- Dec 28, 2014
- SR Viper
I will give you a call Monday if I get time. Where are you located?. I see the 920 so I assume the east side of the state. I'm in central WI....Marshfield. snow is flying here....not enough yet but it's a start.
Manitowoc,Wi 54220I will give you a call Monday if I get time. Where are you located?. I see the 920 so I assume the east side of the state. I'm in central WI....Marshfield. snow is flying here....not enough yet but it's a start.
