cberg84
i put a riaser on my rx-1 mountain with new bars. i removed the pad and cover. now i have all the plugs out in the open. i went to napa and they had 1" wire cover pipe with the cut all the way down the side, i baught it. now the plugs from the handlebars need to be reloacated somewere else. anyone done this? were is the best place to reloacate the plugs too? what wire conectors will work the best without problems of bad connections? post pics if you have them thanks.
chris
chris
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
I installed Fly Aerotaper bars and relocated all the wire connection so they are just in front of the fuel tank. Here are some pictures. In the picture with the Super Charger you can see two of the red wire looms and one white connection. For the splice connectors I used a waterproof heat shrink type butt connector for 16 gauge wire.
rx1mtn
BlgsRX-1mtn, I have been thinking of doing the same thing with the handle bars as you did, what did you use for the throttle cable and brake hose?
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
rx1mtn said:BlgsRX-1mtn, I have been thinking of doing the same thing with the handle bars as you did, what did you use for the throttle cable and brake hose?
My cable is from MPI. They get them from thrusted vector though (send him a PM). My brake line is a stainless steel brake line from SLP. Here's the link for the brake line (part number 27-92) www.startinglineproducts.com/catalog.cf ... ductID=536
Jim
rx1mtn
Thank you VERY much
cberg84
thanks for the info. plan on starting tommarrow. thanks for the pictures they help.
Thatspec
I have a similar setup, and relocated all the plugs under the tank cowling on the drivers right (vicinity of the ignition key).
It was much more involved than I originally thought taking the better part of two evenings. With an 8" riser, 1 1/2" pivot blocks (both powermadd products), and the stock bars off an xr650r (about 2") it came out to about 5" above stock bar height. Was able to use the the stock brake, choke etc. and an '05 RX1M throttle cable which is about $16 from a good dealer. The moto bars are steel so no problems with the hand warmers. They are about .8# heavier than the equivalent Renthal aluminum product but 1/4 the price.
So far so good. Mildly concerned about wire wear under the cowling but its pretty well taped.
Hope this helps, Mark
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I made a four inch riser and added twelve inches to each wire so I could hide everything underneath the shroud. I also used the rubber cover that comes on an 06 vector mtn se to clean up the bottom of the steering post, Ken.
