Handling for RX WARRIOR
Albany, New York area
OK, Let's hear it from the pros.
What is the best set up for high speed trail running on tight twisty trails ?
The trails I normally ride in Quebec are quite wide but this is not the case on the feeder trails.
Let's hear from head to toe.
RX WARRIOR 144 Woody's and 6 Ink Carbides
Let's hear it from ski tip to the rear skid as far as what works best as a set up.
I know ive talked to you before on this... HERE GOES AGAIN!!!
LEave limiter straps alone or tighten them 1/2 inch...
BUY SOME 6 or 8 inch WOODY DUALIES..... ITS A MUST!!!! Tighten the center shock some,, about 1/4 inch....and loosen the clicker on the middle shock ALL THE WAY...
The studs you have are great for tight twisty trails..
I think my warrior rode like a high performance caddilac and handled awsome... BUT DONT THINK YOU DONT HAVE TO LEAN BEAUSE NO MATTER WHAT YOU WILL... ITS A HEAVY MACHINE...
