Red2003
DaveyBoy said:Brian where on ur sled the lower spindle on a-arms ?
I have taken the 2 apart and did as u said the long shaft running aside the frame Are the ones down the steering post needed as well
Yup those too, and the ones below the battery box that hold the bellcrank assembly to the chassis too.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
let us know if it did the trick!Red2003 said:DaveyBoy said:Brian where on ur sled the lower spindle on a-arms ?
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
I will let ya know but i left sled at the cabins so its 7hrs away will try to head up there early friday to get it done so it will be a week
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
I pulled the two on the side of the frame and it is better but needs more attention gues i will try the other few spots although the sled isnt here its 7hrs away now
rxwhopper
cant you just drill threw them and use a needle end on a gun and grease them thaat way, but better use a very light grease
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
Now this brings up a thought i used the yammi lube for grease zerks maybe a little to thick for the steering ,But thats what goes in the spindle HMMM i will have to think for a bit
